dogdaysllc
- Aug 31, 2018
- 9
Mid 90’s Johnson 2-stroke 3hp. Model J3REOD.
Motor is nearly impossible to start. However with just the tiniest squirt of starting fluid into the airbox it fires right up and runs great. I read that starting fluid on 2 strokes is bad so I’ve been spraying some gas/oil mix instead. It’s not nearly as effective as the starting fluid but I can eventually get it running. I’ve replaced the plugs, fuel lines and cleaned the carb (which is spotless). I’ve adjusted the air/fuel mixture screw to where it seems to like (about 1.5 turns out). It would seem like it’s not getting adequate fuel when cold since it fires right up with the starting fluid. Any suggestions?
