I have a 1990 120 Johnson VRO. I have gone out twice this year and have had a hard time starting it both times. Once it is running, it is fine for the rest of the day. It cranks but won't turn over even with the throttle open all the way. To get it to start, I had to flick the choke over ride switch (little red switch on port side of engine). It started right up after this and then I put the switch back the other way. Any ideas as to what I should check/replace?<br /><br />thanks
