Bill kubiak
- Jan 31, 2004
- 629
Hi,<br />I have a 1992 Mercruiser V-8 270 hp engine with a Weber 4 bbl carb. This is in a 1990 Stingray Maxum 222 boat.<br /> I push the throttle all the way forward to set the choke, pump it a few times, and hit the starter, It cranks and then fires for a second and dies, it keeps doing this for 5 or 6 or more times and then it finally starts, When it does start it stumbles for 30 to 45 seconds and then smooths out and purrs. When it is running, it runs great, the problem is always in starting it.<br /><br />Where do you think I should check, the Clymer manual does not talk about this symptom at all???
