Hey everyone,
I just recently bought a 1996 Bayliner 2250 with the 5.7 Merc in it. (I’m familiar with diesels not gas engines so bear with me) This morning I fired my boat up before heading to the lake, worked fine, got out there and it would crank but would not even try to turnover. I got into it and noticed my carb was flooded out and figured I just gave a little much gas trying to start it, but my choke plate also wasn’t opening all the way, let it breath for about 5 mins and after maybe 5 seconds Of cranking it kicked over and started up. Everything was fine, got to the back of the lake and when we tried to start it again the same thing happened. Got it running and on the way back sitting around 4500 rpms it would cut out and lose power. If I backed off it would gather itself and be fine. Got about 100 yards from the ramp and it just completely died. After looking at the carb again I noticed my fuel pump breather tube was pumping gas into the carb! It’s also idling very high at times (around 2,000-2500) so I’m wondering if my diaphragm on the mechanical fuel pump is shot or if I should be looking into adjusting my carb. Thanks for any input.
