Re: Hard steering
Just to add what crazy charlie suggest with cleaning..you also need to keep in mind that at displacment speeds it will steer a bit heavy, when at planing speeds you should be able to trim the drive a bit at a time until you feel the steering losin up a bit,If this is not happening after a cleaning then, I would recommend that you disconnect the steering from the tiller arm from inside and see if you can move the drive from outside the boat, should swing left to right easily, if not then the vertical pins or shafts that mount the gimbal to the gimbal bracket are more than likley worn of seized, also when steering is disconnected turn wheel left to right should be nice a free, BUT the first thing I would look at is at the helm check and see if there is a friction adjustment knob/screw on either the bottem or top side of the steering hub bezel, could just be simply turned in to tight causing alot of drag at the wheel, if thats the case then you can losin it abit.
