Re: HARD STEERING
Try to pinpoint the cause of problem before you start throwing money at it.<br /><br />Disconnect the cable from the motor. <br />The problem could be in the tilt tube on the motor. <br />Or in the motor pivot in the mid section of the motor.<br />Or in the cable(s).<br />Or in the helm itself.<br /><br />With the cable disconnected:<br />Does the motor now turn easily?<br />Do the cables now turn easily?<br /><br />If the cables are the problem, I would replace them.<br /><br />Also, if it is in the helm itself, you may have to replace it, as parts are not available for the older inferior systems. <br /><br />Let us know what you find.
