Re: Hard Steering
Hello Rich and welcome aboard iboats.<br /><br />What I would suggest you to do is remove the steering cable from the engine and see if the steering is easier. If it is, clean the tilt tube out with a round wire brush and get all the gunk and rust out of it. Clean the steering cable ram also. Coat with grease before reassembling.<br /><br />If the steering is still stiff after removing from the steering tube, replace the steering cable. Probably rusting up inside and will only get worse.<br /><br />Please note....sometimes it's necessary to lift the engine from the transom to remove the steering cable from the tilt tube.<br /><br />Post if you have any questions.
