hard to start
thumper1959
2000 ? johnson outbd 130 hp very hard to start initially when been sitting for week once running will start every time even if sits over nite the fuel ball is pumped hard
Re: hard to start
More details required.----Is this motor new to you ?--Have you read an owners manual ?---These motors should start up almost instantly if in good condition.----What is your cold start procedure ?----Important to answer question in order to get help.
boobie
Re: hard to start
Is it just for a week or longer and where are you located at ??
thumper1959
Re: hard to start
Yr
The motor is same year2000 i squeeze the fuel bulb solid and use the choke when turning key live in Fayetteville nc i hold key in whe turnig over and i use the fast idle handle
boobie
Re: hard to start
Are you holding the key in when cranking it over ??
F_R
Re: hard to start
AND using the fast idle/warm-up function on the control?
thumper1959
Re: hard to start
I hold the key when starting and use the fast idle handle when cold starting
Bosunsmate
Re: hard to start
It could be your battery is losing charge.
Disconnect it next time and see if its ok.
Or connect up a multimeter and see if its drawing down- disconnect one batt cable and connect a multimeter between it and the battery and measure if theres any current with everything off
thumper1959
Re: hard to start
Tested battery. Its good and no dtaw on the circuit it turns over good just takrs forever to start almost runs battery. Down before it starts
boobie
Re: hard to start
What ever happened ??? A reply would be nice !!
thumper1959
Re: hard to start
Haven't. Had time to work with it yet mother had surgery helping take care of her will let you know as soon as i can
boobie
Re: hard to start
When you get back, check the private message I sent you.
thumper1959
Re: hard to start
It was oil gas mix but seemed to a little heavy on the oil when it started it smoked bad but did clear up after awhile
