hard to start
douglas32200
i have a 6h evenrude outboard motor and latley its been a real bugger to get started. once it runs it works fine but will not idle. the idling may be the fuel mixture screw. anyway any suggestions?
fireman57
Re: hard to start
Sounds like you might invest in a carb rebuild kit and install it. Probably have junk in there and maybe a jet that is partially clogged. If you post the year or number of your engine that would help. You can also check the FAQs for hard starting.
Solittle
Re: hard to start
Doug - Make sure that you soak the carb in carb cleaner overnight - then get all visible crud out (I use a toothbrush) - then blow it out with compredded air - Do all this before putting in any of the parts from the kit. AND a shop manual is helpful unless you have done this before.<br /><br />OH AND WELCOME!!
douglas32200
Re: hard to start
thanks for the advice. as for the year of the motor i'm not sure. i found the serial # 6302s c 83946, does the serial have the year within the number?
