As per a local Mercruiser supplier, I removed the balancer using a standard gear puller. The outer pulley and flat rubber ring separated from the inner balancer hub. Can this be reaasembled or do I need to buy a new assy. Thank you in advance. The Merc 3.0 has no threads in the crankshaft...is there a preferred methos to getting this on the shaft.
