When I place the shift lever in forward or reverse it makes an abrupt sound that when engageing in gear. I know some noise is normal, but mine sounds a little harsh. I recently had the outdrive off to replace the gimble bearing. I also replaced the prop with a four blade prop. I had the boat shop install the prop. The new prop uses a different hub I believe. My boat is a 1996 Maxum with Alpha Gen II. Engine is a 3.0 140 HP. Does anyone have any ideas? Please advise. <br /><br />Thanks<br />Kevin
