Re: has anyone got the rino spray liner?
The spray on liners are technically known as "polyurea" coatings. Rhino Lining and Line X are two of the more well known brands. If you are going to get it sprayed to fiberglass surfaces surface preparation is critical. do not try to have it applied to a smooth surface, it will not have optimum adhesion. In addition, I would discuss the use of a primer with the installer. They typically spray directly to metal truck beds, but spraying to fiberglass might require the use of either a polyurethane primer or an epoxy primer. A store that sells industrial finishes should be able to help you out with information and a primer recommendation.
