Has the Bayliner Capri 19 foot 1989 a reliable boat?
Status
Not open for further replies.
Patty Pooh
I am thinking about buying one to put in the bay but im not sure on Quality. Thanks
6MISFITZ
Re: Has the Bayliner Capri 19 foot 1989 a reliable boat?
Spend some money to have a marine technician inspect any boat FIRST before you buy regardless of manufacturer!<br />Goodluck, <br />Mike
Solittle
Go to the red search at the top of the page and enter Bayliner. Lots of stuff.
Bayliner.....<br />Quality.....<br /><br />That's an Oxymoron Isn't It ????
magster65
They look sleek but the sides are too low for my liking. The deck trim is only about 9" out of the water normally and if a fat guy stood there it'd be submerged. That's no good.
wvit100
Up until last year I used a '89 bayliner capri, cuddy cabin with a 125 hp force outboard. I never had any problem with it other than I had to replace the fuel pump diaphram. I maintained it well. It always ran around 40 mph and had good power for pulling tubes and stuff. I never had any problems with it sitting low in the water, I know it was a lot higher that 8" out of the water. Depending on how it was maintained it might be a good boat for the lake. Just remember it is 14 years old, nothing lasts for ever.
OKCSOONERS
I have a 1989 Bayliner Capri Cuddy Cabin with a Force 125HP. It has been a great boat. I have not had any major problems with the boat. It has brought my family and I many hours of enjoyment. I would go for it.
dkhntr
If you get that Bayliner, pay attention to detail. Are you able to take it for a test ride? If you are I would definatly do that, if you cannot get a marine tech to check it out. <br /><br />I own an 88 capri 19ft I/O. I love it. I am slowly restoring it over winters here. To ask if it is a reliable boat is bad. I had/have a HUGE issue with Rinker's. After I owned one they are only worthy in a scrap yard to me. Nice boat but mechanically it almost drove me to the funny farm. But hey, That is my own thought.<br /><br />One thing about those 80's Bayliners. They are not good in real rough weather. I have seen plenty with stress cracks because they were bouncing in big waves. I do belive most of that is caused by operator error. However there Fglass was not the greatest back then too. Ergo the stress cracks.
magster65
Here's what I mean, this Capri only has about 11" (tops) from the trim to the water with nobody in it. If a fat guy was standing in the back corner it'd be in the water.
dkhntr
Uhhhh. This is too low? This is a 1989 19ft Capri. <br /><br />
<br /><br />Same boat, one skinny kid + one older bigger lady + one dog = ONE REALLY FAT GUY. Not really sinking in the back.<br /><br />
<br /><br />The last pic the bow is on shore even putting MORE weight aft.
dkhntr
2859 hull core sample. This photo is taken of the 2" dia core that I removed from the hull of my boat for a sonar transducer installation. It was taken approx. 6" port of the keel. If anybody tells you that Bayliner hulls are thin, they don't know. As the photo shows, this core is a full 11/16" thick, and is solid fiberglass. If it was any thicker I would have had to order a extra long stem transducer. This bayliner may not be the most elegant boat on the market but it is a strong, seaworthy boat.<br />
Squirt
I just got a '91 bayliner Capri from my Father.It has a 90 HP Force,2 stroke I/O and a force outdrive.He was probably cursed with this boat.Never had a problem with the hull or anything, but the engine had to have a new starter, coil, then a new crank due to warpage.Then the splines that connect the engine to the steering mechinism stripped out.2 U-Joints in the transmission,Then 2 bearings in the lower unit went out and had to be replaced. Well,I'm a first time boat owner(fairly mechanically inclined,with a book)I figured this had all new parts,so I bought it for myself.The first thing that I did was GREASE EVERTHING and replace the seal in the lower end after my preesure check said it was bad.I have had this boat out twice and have had no problems.I believe that the failures my Father experianced was a lack of preventive maintance from the previous owner.I hope that this helps you. SQUIRT
12Footer
Can we talk here? Bayliner and Force are the two most ripped-upon names in boating.<br />It helps not, that most B'liners have Force motors hanging-on the transom.<br /><br />Bayliner got it's rotten reputaion for it's rotten layup, which leads to rotten wood. The problem isn't soley the amount of material, in most cases, but the care used at applying said materials.<br />This issue,as the issue with Force has been beaten to death, and opinions are like--- well, you know.<br /><br />I own two Bayliners at present..Like Squirt, I got my first from my father, who got it from my brother. It is a 1990 Crapi 1650, with a Force 50HP. It is all original, except for a chunk of the decking that I had to replace.<br />The other Bayliner/Force is a recent aquisition (1989 Cobra Bass/w 50HP),that can be summed-up in two words-- "Basket-case".Pic of the aft decking.;<br />
<br /><br />It needs total redecking. I do not care, as I look-forward to the end-product, and the pride that goes with taking such a neglected craft, and making it worthy enough for an Admiral to carry his flag upon the Caloosahatchee River in.<br />Hey, we all can't afford 31' Contrenders with twin 225 Yammies...Nor could we all afford the fuel such a magnificant craft would eat.<br />But if you plan on purchasing a Bayliner/Force combo of any vintage, be aware of the obvious QC issues, such as poor fiberglass layup, and corners cut in other areas, such as decking not encapulated underneath, nor are the stringers fully coated.<br />I can fully understand the comment on the freeboard, as my "Crapi" doesn't like 2 foot seas <br />.<br />I've had in out in such seas once, and it did well. I wore my lanyard and PFD too!!<br />At anchor, with nobody in the boat, an onshore wave set of 2 feet breached the bow many times (a gathering of "Floridasportsmanonline" forum members). Thanks to a great little bildge pump, she rode it out just fine...But there aint no sides on this boat.she is a definate "River Rat", end of story. She does fine in the river.<br />
<br /><br />The layup problems are obvious once the decking is pulled-up. They used a chopper gun, which in itself,is not a problem, provided you have someone else there to roll the layup in (which they did not have). and they cut costs in materials in that they left the bottom side of the decking uncoated. Nor are the stringers fully encapsulated. In mine, the top wasn't coated iether, (but have learned that is not the norm), and the entire interior has been covered in monkey fir (that cheap, thin,moisture holding carpet that the boating industry is so fond of using).<br />One day soon,I'll have to repair some rot now forming in the anchor box decking cross-brace, and when I dig-in, I'm ripping every stitch of that monkey fir out! Didja ever get a hook caught in that stuff? The Cobra Bass rig has the same stuff in it--Only it's purple!!!!! what were they thinking?<br />Oh well, in closing, you get what you pay for ,usually. So expect such issues. Before buying, walk heavily on every square inch of the decking, loking for 'give' underfoot. Inspect the transom for any cracks in the glass--at all--any cracks there, run.<br />next, pull up the removable cushions in the bow, and check the woodwork underneath. Check under the seats also.<br />Next, even if a sea trial is not possable, have the compression tasted. All else is easy to fix. Compression is the biggie.
Valv
12Footer, sorry I couldn't resist !! You posted you have a 1990 CRAPI instead of Capri.<br /><br />This doesn't help much the Bayliner debate.<br /><br />I am not into the debate, but I really laughed hard. If we were talking about anything else, it would have been just a mispelled name, but on this thread it really cracks me up.<br /><br />No offense, of course, I love this forum and the help you give us. :)
Oh Buoy
I own a 1989 19 ft Bayliner Capri with the 3.0L I/O. There has been problems with cobra outdrive due to a sticky shift cable which cause the clutch dog to go bad thus it jumps out of gear and will eventually fail unless it had the new cable put in in time(mine didn't). I am a big fat guy and the boat does not sit low in the water. I have not had any other problems with my boat. Have it inspected before you buy!!
wvit100
I've had some pretty big people in the boat and never had the water come anywhere near coming into the boat. My '89 Capri looked just like the picture above but with a cuddy cabin.
magster65
Can you see that picture I posted? The one I sea trialed (not positive of the year but it may have been newer) had a 3.0 merc in it and the deck trim was only a few inches out of the water when we stood in the back corner (200+ lbs each). This is a little too close for the type of water we have on the coast. I'm not trying to 'bash' Bayliner. Neat picture.
jocko_nc
My last boat was a 1986 Capri 195 cuddy. I will never own another plywood / carpet / upholstery boat again. The best thing to be said of the boat was the Volvo power, which really is a simple tough beast.<br /><br />If you are seriously looking at a 80's vintage Bayliner, please be advised. I am not going to say they are junk, but they were built for looks and a low initial cost. My boat ran well. Many do. The statements about construction are completely accurate.<br /><br />Please consider the following:<br /><br />Construction is pretty lame, though acceptable for the intended use. The issue is not the "hull" so much as the deck and stringers. Rot from the top down.<br /><br />The typical Bayliner owner is a first-time buyer who bought on price. It is a weekend party boat. Consider the maintenance practices of such an owner.<br /><br />The year and number of hours is irrelevant as compared to the damage that may have been done due to maintenance issues. Especially true w/ a marginal quality boat. The plywood in the construction is the Achilles heel. You get what you pay for. If the boat is mechanically sound, check out the deck for rot. If the deck has soft spots, be concerned that the stringers do as well. If the boat has been dry inside much of its life (and the overcoat never stress cracked) the wood may be fine and boat may have many more years of service left in it.<br /><br />Good luck.<br /><br />jocko
12Footer
No probs, Valv. That's why I took the name plates off, cut them, and re-attached them to read 'CRAPI'. I couldn't resist.<br />I took out my trusty Case knife, pryed the name plates off thehull, took a razor, and carefully cut the "C","AP", "R", and "I" ,and rearanged them back on the hull to read, "CRAPI"..I used 3M Weatherstrip adhesive to re-attach. them. Folks at the ramp look twice. :D :eek:
bjarnold
I am the 1st and 3rd owner of a 1988 Bayliner Capri 19 1/2ft open bow with the 3.0 OMC Cobra I/O with only 102 ORIGINAL hours on it. I have never had any problems with the hull even while in a storm of the coast of Canada with the throttle wide open going slowly going thru the waves.And the only problem is the stiff shift cable. Personally I think it is an excellent quality boat <br /><br />
Status
