Have a problem, Could Factory messed up???
BigBK
Have a 1988 SeaRay Sundancer, Got a small leak in the Y-pipe exhast and was takeing on some water so had to pull the engine. needed a new O ring. The Y-pipe has 4 holes for bolts in it, 2 on top and 2 on bottom. but had only 3 act bolts in it.
after removing it i found thet the gimble plat has 4 hole also . BUT!!! it has one on the top, 2 on the bottom am one on the starboard side the boat has had two owners, myself and my brother neither one of us has ever change the Y-pipe or the gimble. SHOULD I HOOK IT BACK UP THE WAY I FOUND IT. with the 3 bolts or replace the Y with the right one
Re: Have a problem, Could Factory messed up???
Ayuh,... I prefer using the Right parts,...
But,...
According to you, it's been Fine for 20 Years....
Paul eagen
I would look on the internet, you should be able to find an eploded view of the engine and other parts. This would probably give you the best answer.
BigBK
thank you, i looked at an exploded view /s and could not find one that showed all the bolt patterns for both pc. so i can to the conclutio if it has worked this long, well im puting it back on as is. also i had some electrolysis going on around the bottom of the y-pipe. was very little clearance between it and the transom. Had dirt and debrie packed in there. so i cleaned it out and put JB weld around the flange edge and up on it about an inch. fig its not metal base and may give it some protection. i will check ( remove and clean all grounds) to help stop this prob since the engine is out anyway.
