Have fuel, compression, and spark still wont run
28sstony
78 Johnson 150. Changed the filter, pumped about a gallon of gas into a jug with the primer bulb to check for water and it looked fine. All 6 plugs are sparking on their cylinders and the motor has 105 psi on all 6. The carbs were just cleaned and synched, all 3 bowls are full of fuel and the motor still wont fire. My next move is to try a different source of fuel. I'm on vacation with this thing and completely out of ideas.
Thoughts?
R1racer
Re: Have fuel, compression, and spark still wont run
Does it turn over..? is the battery fully charged, check your connection from the battery to the starter & starter solenoid
28sstony
Yes it turns over fine. It just cranks and cranks and wont fire. All the plugs are wet so all cylinders are getting fuel, all 6 plugs are sparking on their respective wires.
There was about 30 gallons of 93 Octane left over from when I last ran the boat in August, treated with Stabill in Nov. I added 30 gal of ethanol free 90 octane two days ago.
R1racer
How can you tell if you getting spark on all 6 plugs , Are you using a tester ...?
Spray pre-mix directly to each carb throat , Pull and clean the wet plugs to dry....Give it a try if it fires up on that you might got some sort of a fuel restriction which is possible .
jonesg
Flooded, open throttle to full , crank it until it starts to pop.
Or remove plugs and crank engine to blast it out of the cylinders.
Make sure spark can jump 3/8th inch gap.
boobie
Dumb question on that mtr but how about the flywheel key ? Does the spark jump a 7/16" open air gap on a spark tester? By the way, how did you check your spark?
swflhummer
yeah sounds like timing is off... Bout the only thing it could be if all other 3 rules are as you described...
jerryjerry05
Yea,if you have good spark and good comp.And the fuel is good then the flywheel key might have sheared.
I had a 88/85hp and it was running great.I shut it down and a week later tried to go fishing.NOTHING.Wouldn't start even if I used starting fluid.
I was a new mechanic at the time and checked everything.Finnaly went to the MASTER(boss) he said pull the flywheel and check.I'm thinking the boss isin't as smart as I thought.No way was it gonna be the problem.It was.I looked for 4 hrs.Changed the key and was running in 10 min.
I don't usually say this but try starting fluid.Just a touch.Too much can cause damage.J
