cdubwebster
- Aug 16, 2012
- 5
I hope someone can help me here.
First thing I want to do is explain my experiences with this issue on the water. The first time I had the boat on the water everything ran perfect! After that the next time I thought I had a misfire problem because it was sputtering and sounded like one cylinder was having an issue firing. I replaced the plugs and it seemed to run great the next time it was on the water. Next time I had it out same thing. loss of power and would not run at full throttle with the sputtering not firing correctly cylinder. I just seemed weird to me that I had low end power and not top end with what sounded to me as a misfiring cylinder. ( sorry this is the only way I can explain) The last time I had the boat out I replaced the spark plugs again thinking that may be the issue! Boat ran fine in the morning and then in the afternoon had problems starting. After getting it running again it was fine until I was ready to leave the lake. Again trouble starting and also after running it out and heading back to shore a complete loss of power. Wide open and it was like I had only cracked it open a little bit. Probably going 5 mph with wot. Any thoughts on what is going on? Also In the begining before I changed plugs first time I had oil res on the bottom Cylinder plug, same after I changed plugs. I thought it may have been fuel oil mix so I leaned out on the oil. Last time I was out no res on the plugs but after the boat sat for a few days before I checked the plugs, there seemed to be rust starting on the screw in part of the plug. I'm not sure if that means I have a bad seal on the bottom Cylinder and getting water in the cylinder or not. Please help this is my first boat and not sure where to start!
Thank you!
Thank you!
