F14CRAZY
Ensign
- Aug 12, 2008
- 945
Before gutting my Capri's hull I detached the sterndrive from the engine and "transmission" at the pivot bearings.
My engine's been running fine and as far as I can tell the sterndrive has been fine too. I've been reading through my Clymer manual but is there much I should replace being that I have the units out of the boat and access is easy? I don't suspect any leaks into the sterndrive so I think I'm okay there. I would like to replace the oil pan gasket and bellows for good luck. OH and the oil plug seals on the sterndrive.
I've heard of other bellows being mentioned but aside from the one at the transom, my Series 400 OMC doesn't have any other bellows, does it?
How much wear can the ball gears take? Not an accurate description but I'd say mine are about halfway though...I'm thinking these are in bad shape and I should replace them at this point.
But yea, aside from assembling everything back together according to the manual, and what I've said, should I inspect or replace anything else?
