ZSBrownlee
- Apr 2, 2019
- 15
Hello all, I am having a problem with my 87 40 hp 2 stroke Johnson. Boat was given to me by my grandfather but I have used this boat my entire life. When I first got it, I took it out and it ran great. Then I shut it off and fired it up again and it wouldn't get on plane. I got home and bought carb kits for the 2 carbs. I took them completely apart then let them soak. After a couple days I put them back together with the parts included in the kit. Well I replaced some fuel lines and spark plugs while I was at it. I ran it on muffs and it ran great. Took it to the water and it will only stay idling if I push in the key every once and a while, which activates primer solenoid to give it gas. I can put it in gear and get to higher rpms. It just won't stay at an idle. Really need some help here. Thanks
