having a Beavis moment
coolbri70
bead blaster.jpg have one of these at work, i was curious as to how far this might toss a potato:confused: and dont want to try for fear of being terminated:facepalm: maybe someone has tried this:confused:
sam60
Re: having a Beavis moment
I've never used one of those, but my ABS Fitting and grill igniter version can shoot a potato about 700' with hair spray. A little farther with 10% WD-40.
I am not a red neck..:)
coolbri70
it's a tire bead seater, it kicks like a 12 guage when you open the valve
coolbri70
The next time the boss leaves me unsupervised I will find out. I have the idea now I must find out
it should toss a potato about a block minimum
Heck, my PVC bead launching / tee shirt launching cannons for Gasparilla will toss a potato half a block with only 1/8th the air volume. They shoot ice cubes about 3 blocks.
GTS225
Ummmmm...maybe that's why he does the supervising?
Start out with low pressures, and don't aim at the porta-john. The hair spray fuels only generate about 30psi in a PVC cannon. You do that with a full 120psi, and that potato will be GONE!!!
Roger
halfmoa
Ensign
I made the switch to integrated propane and never looked back. Less hassle and way WAY less mess.
To the OP, I've never used a bead seater as a launcher but there's a whole bunch of guys that have air launchers and they're impressive. If it wasn't cost prohibitive I'd have made one already.
kenmyfam
Only had a hair spray spud cannon but that looks like a lot of fun if you ae in the middle of nowhere.
coolbri70
i'm going to think of an excuse and get the boss to let me bring home for the evening:D just gotta think up some excuse:rolleyes:
matt167
My brother and I built an air cannon years ago. Had to either cut down the potato to fit in the barrel we used ( 2" IIRC ), or it would launch caulk tubes perfectly. 100 PSI, we could launch about a football field
halfmoa
Ensign
Well, that depends on the type of boss you have. I've worked in a few places where, "Hey boss, can I take this home for the weekend and see how far it'll launch a 'tater?" would've worked just fine.
Maybe you can leave off everything after the conjunction and see how that goes?
Oh yea, video is nice too....just sayin'.
Grub54891
My spud gun will launch em about 200 yards on hairspray.
