Well, this 1975 Glastron came originally with a 1973, 150hp Mercury, with a "Trigger" ignition (with distributer).
I have put a 1981 HP Mercury with the newer style ignition.
From day 1 (last year) the tachometer never worked. When you turn the key on the tack goes to 2K and when started the tach just flutters around the 0 mark.
Also, it didn't seem to charge battery. So, using the Mercury procedure I checked the diodes and found that it failed test #2 with continuity from Ground to the Alt. Pins.
So, I replaced with a RS 25A rectifier. Tach does the same thing, so I suspect the tach is NOT compatible with this style ignition???
With a digital VM I get 12.5V at battery when off, and when running, I get scolling, unintelligable numbers. Could be I need to check with an analogue gage, but still does what it was with original diode.
Any I deas or questions?? Thanks, Bill
