Volvo Penta 5.7 Gxi-F always starts perfect when cold, but when it gets warmed up, you need to prime throttle (no need full open, 1/4 may be enough)
It Starts again fine if it sits for maybe 2-3 hours after running (requiring longer in summer time).
idle RPM are stable around 700 RPM.
Have no DTCs active and ECU triggers them whenever you disconnect a sensor e,g ECT.
Replaced thermostat, ECT, IAC, TP, MAP, Spark plugs, Ignition coil, FPR, Fuel injectors...
Fuel pressure is correct and engine performance as well, it reaches 30 knots easily at 4200 RPM, didn' t go further though it still has some RPM there.
Any thoughts on what might be happening ?
