when i got motor it died and i thought bad gas or something, well seems to not be the case. This is a 1996 15 hp mariner with a WMC series carburetor with a integral fuel pump. I have been De-carbonizing motor and kept noticing after a bit it would die out because of no fuel, pumped primer bulb and it was good to go gets hard then again i can see that fuel filter gets lower and lower but as if the motor will not pull more fuel. now when i was decarbonizing and had throttle up seemed fine but at idle it acts like fuel pump just isnt pulling hard enough, well looked in service manual and it has no external fuel pump it is inside the carb. Before i new this and when i looked at it when i bought it did this also but i just thought it was were it sat awhile bad fuel etc...When i tilted it up i seen it leaked fuel a bit not dripping but could smell fuel so i ordered carb re-build kit, here is a link to show my carb maybe my carb is the one in the manual lol who knows..
http://mercuryperformance.com/produ...arburetor Assembly (0G760300).jpg&w=600&h=579
I have no idea why it is not pulling fuel, there is a extra diaphragm that came in kit i dont know if it needs the extra one or??? i went by what was on it before and bye my service manual but it does say can be different from pics in manual. here is the one in the manual..
The first pic is a different one i found. Maybe it doesnt need gasket #13 in the service manual pic i dont know the internal fuel pump is #25 maybe the diaphragm has to be on the pump without gasket #13 and only diaphragm #56 but the extra diaphragm that is not in the manual might go on it?????
the one on left is the old one that came off carb and the one on the right is the one that is not in any of the diagrams but the holes line up????? hope you guys can help thanks sorry so long but had to explain right to give you guys all the info.....
