Having to hold in the choke Johnson 1989 130 Seahorse
sdverne
Hey guys,
So I have 1989 Johnson 130 seahorse, that I had the carbs cleaned, and serviced along with a new fuel pump put in about 2 months ago. Now it seems that if I try to put the motor in gear it kills the motor. Out of gear, and full throttle works just fine. Well I found out that if I push in on the choke with my key, it will keep the motor running. Also at lower speeds it sounds like its bogging down a bit, until I push in on the choke then you can hear the motor pick back up. Suggestions?
bernd64
Re: Having to hold in the choke Johnson 1989 130 Seahorse
the carbs have some trash in it seen this before.clean carbs and clean carbs a 2 thinks.check your carb bowles
