Re: Having trouble getting up on plane.
Obviously had problems before. I think he's already gotten advise from this forum because there is a trim tab installed. I think Nautijohn may have recommended the wrong size though
The real reason you are having trouble is because the motor is not trimmed down properly and it is mounted too low. Install a hydraulic jack plate, ventilate the prop, adjust the deflection angle of the tabs, trim the motor down, give the motor a new coat of paint, wax the bottom of the boat, sync and link the carbs, do a decarb, rebuild the carb and fuel pump, install a hood ornament or at least a flag and then it should fly like...like.... well whatever it is.
