I have been using a slide hammer puller with both the three jaw attachment, plus the single hook/ledge style attachment. Having no success. Tried using a long, sharp screwdriver to cut into the seal, no luck. Any suggestions?
When I use the puller it feels like I am hooked on a solid piece of metal. Perhaps the attachment is slightly too far inside? I am thinking that the original seal is glued in, but there is no hint of movement. I also cut into the inside of the seal with a dremel tool, thinking that might weaken the seal.
Any suggestions welcome.
The gray colored ring with four equally spaced circle imprints should be the seal itself. The size exactly matches the new part, VP 3852272. However I see not seam or gap between it and the area that the bearing sits against.
