Head bolt torque ??
KaGee
80's vintage 3.8L V6.<br />SELOC manual says 65lbs.<br />Mitchell Manual for a 82 Chevy 3.8L says 95lbs.<br />Seems to me that SELOC is off (no surprise) a bit. But... :confused: <br />Which do I do? One of the above or somewhere in the middle??
cc lancer
Re: Head bolt torque ??
Seems to me that SELOC is off (no surprise) a bit. But... <br /><br />Good thing you said that here instead of BoatingABC.Com, over there you would be Tar and Feathered, Drawn and Quartered, then Burned at the Stake for saying that.<br /><br />An esteemed member of this forum who I think is smarter than the majority over there, brought an error to the attention of all, and he was<br />blasted.<br />In regard to your question 95 sounds good to me
Dunaruna
Clymer manual says 66 ft.lb (first 37, final 66)<br /><br />Dunno which one is right :confused: <br /><br />Aldo
KaGee
A friend led me here Gearhead Racing <br />They also listed 65lbs for all the SBC's.<br />So that's what I settled for. Did it in three steps... 35, 50, 65.<br /><br />CC... I gotta eat crow on that one. :eek: However, when going over my sterndrive, SELOC was incomplete on a lot of info concerning my unit.<br />They also lack info on torquing sequence for my engine on the heads and intake. Had to consult Mitchell for that info. I'm glad I got the manual, but it's not all it's cracked up to be.
qystan
KaGee<br /><br />Just to share my head tightening experience, sounds like some exotic torture :D :D <br /><br />I had to repeat the torque in the last step another 2 rounds to get it seated. <br /><br />After reaching the 65ft-lb in the third step and the last bolt, I went over the first bolt again and it could turn further before reaching the setting. Went through it again and the third round showed all to be at the set torque.
steve n carol
KG, is this your boat/engine? I was wondering if the people that re manned your v6 were going to do the work on it? You mentioned that they were going to work with you and were very helpful. What happens if there is a further problem after you work on this unit?..sl
KaGee
Ya buddy, I'm into torture! :D <br /><br />When I get back, I'll go over them one more time<br />before I bolt down the valve cover.
KaGee
Originally posted by steve n carol:<br /> KG, is this your boat/engine? I was wondering if the people that re manned your v6 were going to do the work on it? You mentioned that they were going to work with you and were very helpful. What happens if there is a further problem after you work on this unit?..sl
I would have to ship the engine back, so for now I am happy to do this. The engine shop gave me a list of things to check, I went over that list and then some. He is helpful. And I don't want to have to pull the engine if I don't have to.<br /><br />My son helped me with the intake the first time around and he did not put enough sealant on the front and back surface and I discovered it was leaking oil near the distributor and oil sender. So, It had to come off anyway. I just decided to go a step further and remove the head to eliminate a possibility of a bad gasket.
steve n carol
I am glad that you got your son there with you. get some pics of it! It'll be a treasure. how old/young is he?///sl
ron7000
Banned
Originally posted by KaGee:<br /> 80's vintage 3.8L V6.<br />Which do I do? One of the above or somewhere in the middle??
Usually, the torque value of a bolt, or stud & nut, depends on it's material, size, and thread.<br />I'm not too familiar with your v-6, but I'm guessing the recommendation of 65 lb-ft, as in the case of gearhead racing's #'s, is for a 7/16" diameter head bolt. I guess all SBC's have 7/16" head bolts? If you have 1/2" bolts, then it would be 95 lb-ft. And that would be for lubed threads, typically by 30 weight oil. A good source for more info would be ARP fasteners www.arp-bolts.com Another, if you are using them, is fel-pro's website.
