Hello Forum members. Just joined but have reading the posts for some time and have not seen a problem quite like mine. I have a 1986 Searay with a 140 hp engine that I could not get to idle properly. Noticed that the carb was leaking gas into the ports after shut off. I rebuilt it, but it still not fix the problem. After I hauld it out for winter storage, I decided to do a compression check. I found no compression in #2 and very little in #3. I checked with my mechanic and he told me I had valve problems or the timing gear was worn. After removing the head, I found out that I had a blown head gasket between #2 and #3 cylinders. 2 questions.1- Should I just replace the gasket or go the whole way and have the head milled and the valves done. As you guys know it is an old engine and I don't want to put too much stress on the bottom end. 2- What is the best way to plug the rod holes when I clean off the surface of the engine block. Any suggestions greatly appreciated. Thanks. J. Todd
