heat exchanger AQ131A
tincup67
what can i do to make sure my heat exchanger is working properly? I have it removed from the motor and i would like to make sure it is functioning properly before i install it and run the motor. I just had motor repaired for leaking head gasket. How do you determine if a heat exchanger is working properly?
Re: heat exchanger AQ131A
Ayuh,... Welcome Aboard,... With a Flow test, 'n a Pressure test...
greekfreek
The manual I have says to disassemble it and clean the exchanger with muriatic acid. I owned a AQ131D with heat exchanger for years, never cleaned it. What does your temp gauge read?
