heat exchanger
starsnstripers
Can you have a heatexchanger (old style) with no cover or fill? Do you ad an expansion bottle to it? Would it be piped into one line or? L6 165 merc. I have a 4"x20"+ heat ex. I'd like to put it to use but it has only two larger in/out-fw and two smaller in/outs-rw. How would i plumb this?
starsnstripers
Re: heat exchanger
Well, yes and no I dont have a therm. housing with a tank on it like that. I was wongering if i can plumb one into the system e.g. Like an auto:eek: I didnt say that. SHHHH ;) I'll see if i can locate such an animal. Tank w/thermostat thingy.
achris
More fish than mountain goat
Re: heat exchanger
If you don't have an area for expansion/tank, then as the water gets hot and tries to expand, you'll likely pop a core plug... Not good! And how would you fill it? Take a hose off? and checking it before each days use? Messy!!!
:D:D:D:D
starsnstripers
Re: heat exchanger
Oh OK, I just dont ever remember seeing one anywhere. Ive seen the exchanger with the fill/pressure cap only. Guess i'm on another mission to find one of those. I just got a starter(marine) that trim sender(orig. equip):) and an oil pan for my 292(marine) :D Does that rig have a name? Thermostat tank?
starsnstripers
Re: heat exchanger
Forget that last stupid ? Ofcoarse not geesh my housing bolts square to the block. brain cramp sorry.
starsnstripers
Re: heat exchanger
Does anyone have a part# maybe sierra? picture? Dimensions? I'm not sure if i can mount it on the therm. housing because it's a L6 with little room between front of eng. and engine cover. So if there's not enough room can't i mount and plumb Any expansion tank in another spot in the compartment?
starsnstripers
Re: heat exchanger
Can i do this? I'd like to cool the manifold with fresh water too. And just dump the raw water out the riser. See attached changes, hope it can be understood. Or how should it be done to cool manifold with fresh water? Thanks
Re: heat exchanger
Ayuh,..... Sorta, but quite like that.....
PM FreebeTony,.... He self-engineered exactly what you're trying to do, a few years ago.....
Maybe he still has the pictures of His.....
starsnstripers
Re: heat exchanger
Got it Bond-o Does that heat ex. look big enough to cool a full system (manifolds)? I dont see why I can't "T" in a remote expansion tank?
Re: heat exchanger
What does it Measure,..??...
starsnstripers
Re: heat exchanger
It's about 4" x 22" Bond-o ive been looking at the threads from freebe and i haven't found a pic yet, still lookin
