trebor0301
- Jul 1, 2004
- 166
AQ125A heat exchanger question. The actual exchager itself,which side is the anti-freeze side of the exchange.Does it go thru the inside(tube side)or the outside(shell side)?
Thats confusing. KISS. Antifreeze/coolant tubing is surrounded by the cooling waterOriginally posted by J.kopec:<br /> When you pull off the end cap & look in, you are looking at the sea water side......So, the shell is the anti-freeze side.....And you can't really see any of it....JK
posted October 19, 2005 10:48 AM<br />--------------------------------------------------------------------------------<br /> AQ125A heat exchanger question. The actual exchager itself,which side is the anti-freeze side of the exchange.Does it go thru the inside(tube side)or the outside(shell side)? <br />
posted October 19, 2005 11:05 AM<br />--------------------------------------------------------------------------------<br /> When you pull off the end cap & look in, you are looking at the sea water side......So, the shell is the anti-freeze side.....And you can't really see any of it....JK <br />
The engine coolant/anti-freeze is on the shell or out-side.... Asked & answered IMHO....I would be happy to elaborate further if anyone is still confused....JKThats confusing. KISS. Antifreeze/coolant tubing is surrounded by the cooling water <br />
What the heck, give it a try and find out. I would just be careful not to overpressurize it and blow it up.<br />Then after you get it cleared, there should be a sea water strainer under the cap. It will keep the heat exchanger from filling up with seaweed.<br />(Look at my previous post, I edited the picture to show the strainer)Thanks for the advice.Instead of removing the exchanger,do you think I could blow in compressed air thru the drain hole on the bottom?
