Heat exchangers
philbullet
Would a 350 mag heat exchanger with on a 4.3 lx motor? And I know the 1year rules.lol
stonyloam
Sure. Just like putting a bigger radiator in your car. In a closed system the thermostat controls your engine temp.
With a few exceptions. The 4.3 was only offered in a half system. The 350 Mag may be a half system or a full system. Most of the 350 mags were bravo drives and the block mounted raw water pump pushes more pressure and volume than the leg mounted raw water pump. Putting too large a heat exchanger on the 4.3 is not a good idea. Mercruiser has about 75 active heat exchanger part numbers for a reason.
