heater install
dadwayne
I have a 165 mercury i\o and I have a boat heater, how can I install this, the one that comes out of the leg is cold water, need to figure out how to hook it to the closed system
thanks
wayne
oops!
Re: heater install
on your engine water pump.....there should be an extra outlett that is capped off with a plug......get a fitting that will take a 5/8ths heater hose. and run the input line to the heater from there....
the output is easy....send it to a "t" in the hot water feed line to the heat exchanger.....
if you can join it to the block thats better.....but the "t" system will work.
enjoy your heater.....they make all the difference when you are damp from swimming or skiing when the sun is not the hottest.
cheers
oops
achris
More fish than mountain goat
Re: heater install
Is your '165' a 4 cylinder or a 6 cylinder? Completely different hook ups...
Chris.........
Re: heater install
Ayuh,... Ya got it Backwards Oops...
The plug in the circulating waterpump is the low-pressure Return...
The Hi-pressure feed is pulled off the intake manifold, Before the T-Stat housing...
Don S
Re: heater install
He has the 4 cyl (470 style) 165, in an 87 Wellcraft.
Dadwayne, if you downloaded the OEM service manual as I suggested in a previous post, go to pages 6A-12 and 6A-13. It explains how to tap into your engines cooling system. Nothing goes in the intake manifold or the circulation pump, that's for V8 engines.
fgz
Re: heater install
Don, I have a 96 Malibu with a Indmar 5.7. The heater has never worked correctly ( not getting hot ). The engine temp is correct about 145-150. The Pplumbing goes from a nipple on the side of the recirc pump to the heater core and back to the top of intake manifold near t-stat. It appears as if these are both outlets. Could i use the top port on the recirc pump as an inlet? Hope this makes sense!
FGZ
Don S
Re: heater install
fgz, best to start a new thread with your problem, not hijack someone elses thread.
Don S
Re: heater install
Look at the page numbers in the manual.
dadwayne
add heater
add heater
I have 165 mercury in\out and added a heater in it. put 2 elbose in it on the rad hose o n the right , but went from 1 3\4 in hose to heater hose 3\4. temp went to 185. is there a easyer way to hook up heater,?
thanks
wayne
Don S
Re: add heater
Re: add heater
You don't use elbows, you use Tee's.
attachment.php
Don S
Re: add heater
Re: add heater
huh? you understood what he was asking?
Yes, he posted a few days ago on how to install a heater on his engine. I just happened to remember it.:)
Don S
Re: add heater
Re: add heater
I merged the two threads together, dadwayne, in the future don't open 2 threads on the same subject.
