I have a Triton 2070 aluminum boat, it's rated for a 115hp. So I put a 115 Honda on it and it porpoises pretty bad. I haven't tried a hydrofoil, trim tabs, or jack plate (yet...), but I'm concerned about the overall weight of my engine being the problem ( 486lbs ). This boat hull is a heavy hull, weighing well over 1000 lbs, plus it is rated for a 115 engine. Also, my engine hasn't been adjusted for height either, it's set from the dealership as low as possible. Do you think I'm just stuck with this problem due to the weight, or is there hope with the afore mentioned additions and/or adjustments?<br /><br />Thanks, I'm getting despirate for help !!<br />Russ
