what are the odds that I have damaged a DT15 suzuki 2str. The impellor was bad and I ran it, and it over heated. It got so hot it turned off. I didn't know the impellor was bad. I went ahead at compression tested both cylinders and they read 110psi on each. Do you think there is a chance the motor was damaged? thank you
