I’ve search the internet for 2 weeks to solve my problem with no results. I have a 1987 3.0 Mercruiser that I changed the points to EI Protonix and flame thrower 3.0 ohm coil. A lot of directions call for taking the purple wire off and running a wire from positive side of the coil to the ignition switch hot side or to the alternator. I unhooked purple resistor wire, ran a 12 gauge wire to the switch. FIRE!! Melted the positive wire for the distributor to the coil. Also boat wouldn’t stay running but did fire trying to start. Removed wire to switch, reconnected purple wire after tapping the melted wire covering. Fired right up. Second attempt- removed purple wire and ran a hot wire from coil to the alternator. Same issue but no FIRE. Boat tried to start but didn’t. So with all that information my problem is this. Boat starts and idles great. Boat runs great until about 1/2 to 3/4 throttle. Boat motor stops running at that point but starts right back up. I suspect a voltage drop but can’t figure out the issue. I don’t see a resistor anywhere. Anybody else had the issue before. Any suggestions would be great
