helicoiling spark plugs?
I have a 1975 johnson 85hp V4 that the previous owner has apparently already pushed the spark plugs thread to the limit and I finished off the job this past weekend. Stripped it out of course......what would be my best route to fix this problem....I am assuming I can helicoil it but I figured i should ask someone with more knowledge than me. thanks for the help
Walker
Re: helicoiling spark plugs?
Heli-coil will work fine. Best bet is to pull the head first so you don't get aluminum shavings in the cylinder
papasage
there is a sparkplug insert . i like it better than a helicoil . i ahve put them without pulling head with no probablem . put some heavy berring grease on the threader and that will acumilate most if not all the shavinge and after the work is don spinn motor over to blow out any shaving . you can wash cylinder out by pourinh a gass oil mix from tank and then spinnover with plug out . i did one at the lake and never no probablem . maby just lucky . had to go fishing
Where can I get one of these inserts you speak of.....Sounds like a good deal if i can find one.
what66
I found one at a auto part store worked great.<br />try your local auto store I bet the can help good luck.
Thanks guys ...I found that thread repair kit and it was so simple........thanks alot for the help.
