I have a 7.5 1958 evinrude. And I cant figure out what the problem is with it. First off our biggest problem was that the person who had it before thought the fuel mixture was 50 to 1, but it wasnt ran much on this mixture, and was ran very little back in its day. Anyhow the problem is this.... We can get it to run fine set it up in a bucket with water, we had it idling for over half hour, rev it up a bit, it works good. But heres where the problem starts, we go down to the lake with the boat and motor to try her out in the water it starts up fine no problems, but when you put it in gear it runs fine but when you go to give it more throttle the engine doesnt really rev up and has no power, or its fighting something, either way it wont rev high up withthe gas and the speed doesnt change lol.
Then what happens is when you drop the throttle, it dies, wont start again for a while, and sometimes you cant pull it. Its almost like it seizes, but if you let it sit or take the coil off and play with the top end you can spin it backwards till spinning it proper frees up. I dont know a whole lot about this stuff havnt really looked at it yet, sorta looking for starting points. thinking maybe something jamming the gears, hoping nothing major lol.
Sorry for such a long confusing blog here, but i need help and any ideas or thoughts would be greatly appreciated. thanks Jon
