HELP 1974 50 HP Johnson No spark
aaromba
model #50ESL73R serial # E3827500. No spark on either cylinder. Some times it would start then the next time it wont, now I cant get it started. I did The CDI check the resistance on my stator is 870 ohms ( which is high to 500). Kill switch check didnt help. I think it might be the power pack does anyone know how to check them. I hate to spend $100 dollars and not know if thats it or not.
aaromba
Re: HELP 1974 50 HP Johnson No spark
Went there and did that but when do you know if the pack is bad. My resistance is high at 870 and my voltage is low at 76 (150). Also should this be DC volts or Ac
