Purchased this motor last week from a marine mechanic. It is model number 25502B. Motor had been stored for years. Very clean, low hours. Seller supposedly put new points, carb kit, fuel pump and fuel lines as well as new impeller. The day I purchased it, we checked compression (106 and 110), cold started it and it ran great. I get it home, it sets for a week, I take it out and it starts fine but it dies after a few minutes and now won'tr start. Plugs aren't fouled but I noticed after choking carb that I have a small amount of gas coming out of choke hole on carb. Thought maybe float was stuck but gas tank bulb pumps up tight. Going to check for spark later but I am looking for any suggestions. The only problem with the motor is the kill switch was bad and had been removed so the only way to currently kill it is to throttle it all the way down. Didn't think this could cause an issue but what do I know. Help please...very frustrated...
