Re: HELP 1976 9.8 NO SPARK
You'll find two wires go to the stop switch in the tiller handle.. One is ground, the other is the 'kill' wire. Ground the kill wire and the spark stops. Do that witht he engine running and the engine stops. Easy. If the kill wire is shorted to ground anywhere, you have no spark. Find that wire and remove it from the power pack/switch box. Is spark present? If yes, you have a short somewhere in that wire, or the stop switch in the tiller is crook. If there is still no spark you have a faulty switch box or trigger. The trigger is one of the coils up under the flywheel (the bit that spins) that 'tells' the switchbox when to, umm, switch (make a spark).<br /><br />Hope this helps,<br /><br />Chris..................
