Re: Help 1992 135 mariner & rookie owner!
Over time cranking speed slows down, and we do not tend to notice it as it is such a gradual change it seems like it has 'always' cranked fine.
There is a minimum cranking speed for the stator to generate sufficient voltage to operate the ignition system.
Dirty battery cable connections, ditto the starter cable, dirty commutator and brushes within the starter, dry bushings within the starter. All combine to reduce starter speed. Disconnect and sand EVERY cable end, battery cables and starter cable. Make SURE the battery is fully charged, take it somewhere and have it LOAD TESTED to be sure of its condition. Disassemble the starter, lightly sand the commutator clean, very lightly oil the bushings.
