HELP!!!! 2003 Johnson 90 hp
2003 Johnson 90hp v4 lower unit removal got all the bolts just cant figure out the shifter rod disconnection how to get it off to remove the lower unit for prop shaft replacement
thanks
andy
Chris1956
If it is like my '98 Johnny, you need to remove the clevis pin under the carbs and slide the linkage to your left. The pin will come out of the hole in the shift rod, releasing it.
ok I give how do you get the prop shaft out ..... I have the lower end off and the drive shaft that is vertical and has a bevel gear on the end is what I cant get off now to pull the prop shaft out the vertical bevel gear is in the way!!!
Chris1956
You will want to get a factory service manual, as I assume you will want to shim the gears properly, after you install the new propshaft.
