changed water pump impeller and took it out for a test run. when i was out my overheat alarm went off. so i brought the boat back in and dropped the lower unit. it smoked a little bit. the water tube wasn't in correctly. put it back together correctly.took boat for a ride. it work fine for about 10 minutes then it gradually die. try to get it started again and nothing drained battery trying.<br /><br /> next day and my spare battery, tried to start it thinking i flooded it the day before and nothing. <br />couldn't get it to turn over. DEAD BATTERY 10 minutes later. took the fuel i had and dump it and put fresh fuel in. tried to drain as much old gas from motor. <br /><br />next day go with two batterys pull plugs didnt look bad, got it to start for about 2 minutes then nothing after that. DEAD DEAD when it ran for the two minutes i tried to go full throttle and it seemed like it was at half power. Help help<br /><br />sorry for beening so long, but wanted you to have background to work with. what should compession be at, want to test that tommorow. thank in advance
