05GlastronSX
- May 29, 2005
- 437
I have 2 boats, 1 is a glastron with a 2005 Merc 150. My second boat (and the one I am having a problem with) is a 16.5' fisher with a 40 Merc on it.<br /><br />I bought the motor used, it is a 1992, 4 cyl, oil injected 40 H.p. It was rigged as a console steering unit with I had the dealer convert to a tiller unit for the boat.<br /><br />All the tiller components were purchased new by the dealer from Mercury in 2000. We winterized the motor last fall and it had been working just fine since owenership.<br /><br />We went to put her in the Lake on Thursday night and she fired right up and sounded fine. I let her warm up and went to put it into reverse and nothing. No grinding noise, no clunking, no sound of shifting into-out of gear. Same is true for the forward gear.<br /><br />I took off the cover to make sure the cables were moving / functioning and they are. Is there a problem with the lower unit or is it just a small cable problem?<br /><br />I'm not a mechanic so any suggestions and direction would be great.
