Hey guys I did some searching and didn't see everything that I wanted. I noticed oil in my bilge and the gear oil res was down less than .5L. Filled it up and tried to find the leak with no luck. Went out for a few hours and watched the level, it did drop a little bit so I topped it up and continued to search for the leak. More oil in the bilge and on the second top up I noticed the oil in the reservoir was milky. Im guessing that means water contaminated oil? Any advice for a boating newb? I have worked on cars, trucks, jeeps and even semi's all my life so I am not useless with a wrench. Its in a 05 bayliner if that helps.
