terrysandlin
- Jul 26, 2012
- 67
In my 9.5 hp Evinrude it takes about half of a rotation (90 degrees) of my driveshaft to turn the prop from forward to reverse and vice versus. I previously said that I had some play in my driveshaft in going from forward to reverse etc. and I was told this was normal; but, I did not mention how much play. I lifted the driveshaft about an inch when removing the impeller on the water pump. I pushed the driveshaft back down and it did turn the prop with the above mentioned play. (I do not know what forward/neutral/reverse setting was originally on the motor when I removed the lower unit.) Is THIS MUCH play normal? I just don't want to screw things up when I start the outboard. I apologize for not being more specific in my earlier post. Many thanks!
Terry Sandlin
Topeka, KS
Terry Sandlin
Topeka, KS
