Ok guys here we go, My friend has bought a 1987 BAYLINER 1950 CAPRI CUDDY 3.0 L CHEVY OMC W/ COBRA FOOT when we first started messing with it we could get any Fire from the coil. We got that problem worked out but the motor still will not crank. We took the carb. off and had it rebuilt so we know that it is fine now.
My question is now how do i check the timing and the firing order. It is like a standard motor or is it different. I know in a regular motor you get the number one piston up at TDC and your rotor button should be pointing at the number 1 plug.
Any help would be great guys and thanks in advance for any replies.
Will
Will
