Can you guys give me some suggestions what might happend with my boat. I have 2003 bayliner 1950 capri. Its mercruiser 3.0 engine. I took my batteries out over the winter. When i put one back i accidentaly reverse contacts. It was spark and it took main circuit braker on top of the engine out. Also it took out some gray block that look like relay but only 2 contacts. This block is about 8 inches far from main circuit braker. I reset the both and tried 2 start the boat. It turned over for a second and then there was no electricity for about 2 minutes. After 2 minutes gauges lights turned on but it want start the engine and there is no power to gauges. There is power for horn, gauges lights, bilge pump, stern motor and fan, but no power to gauges and cant start. Also i have checked voltage at main circuit braker imidiatelly after it happend and there was no voltage. After 2 min voltage was there. Any clue what could be wrong?
