HELP! Boat is in water trim stuck up!?!
Odawg753
Hey guys I know when out of wAter I manually release that screw. But can I do the same in the water?? I'm on the boat now with tools and stuck and need to get it down. Any suggestion?
interalian
Sure. Go ahead and release the manual screw. Do you have power trim? Those rams should go down under power, then tighten the screw.
interalian
Oh, and if you need the motor trimmed up higher than base, you may want to move the stop pin to a hole farther out before you drop it fully.
