help! boat won't go into gear
chad dehaven
mercruiser 5.0 liter 305, took our new to us 1988 boat out and after about 1 minute of acceleration, the engine stalled. It started back up, but would not go into gear, no prop movement. there was a funny smell. hard to describe. what could this be???? kids are bummed. thanks for any help
Don S
Re: help! boat won't go into gear
Probably a spun coupler. I would guess the smell was burned rubber?
Ayuh,..........
The Good News is,.......
That a New Coupler will only run you a couple Hundred Bucks,......
Bad News is,......
You have to Pull the Drive,+ then the Engine to Replace it......
Haut Medoc
Ayuh,..........
Bad News is,......
And.....
Find out why the engine is out of alignment......;)
Did it overheat?.....
Welcome to iboats, btw.........:)
chad dehaven
thank for your reply. I guess we'll have to take it for repair. what causes this problem?
Haut Medoc
Poor engine alignment.....;)
Hopfully it is just the rear motor mounts, not a bad transom....:)
